Valve lash theory
https://slantsix.org/forum/viewtopic.php?t=30666
Page 1 of 1
Author:  Valleyant [ Thu Aug 21, 2008 10:47 am ]
Post subject:  Valve lash theory
Considering I am working on a reasonably healthy 49K slant engine circa '72....can I assume that the cylinders that will benefit the MOST from a valve lash are the cylinders that affect the smoothness of idle quality the LEAST when pulling sparkplug wires. just to clarify, some cylinders will cause a major shake/skip when spark is removed (I would consider them major players) but some are barely noticeable when removing spark. Does this theory fly?? Thanks, nico
Author:  Joshie225 [ Thu Aug 21, 2008 10:52 am ]
The theory is sound only if those cylinder not pulling their own weight are misfiring due to their valves being held open from a deficit of lash.
Author:  SlantSixDan [ Thu Aug 21, 2008 11:09 am ]
Josh is right, but it doesn't bear worrying about which cylinders will benefit more or less than which other cylinders from correct valve lash. Just adjust all the valves correctly — here's the valve adjustment procedure.
