no balls
https://slantsix.org/forum/viewtopic.php?t=30667
Page 1 of 1
Author:  kit [ Thu Aug 21, 2008 11:04 am ]
Post subject:  no balls
I just pulled the 1979 slant out of my van and installed a reman from a 1963 valiant. It runs good but does not seem to have the power my old engine once had. I reused all the original intake and electronic ignition, I stayed with the carb that came on the 1963 motor,(it seems to run way better with this one). I was just wondering what is some tricks to get some more nuts out of these engines? I assume getting a 2 barrel intake and carb, or anything else? It is a daily driver so I dont want to compromise the fuel millage or dependibility to much.
Author:  slantsixbob [ Thu Aug 21, 2008 12:15 pm ]
what motor was in the van originally? was it the same size as the replacement motor? if the valiant had a 225 and the van had a 292 or something larger that could explain the slight power loss, but theres also that chance that the other car had a 318. but thats just my guess/off the top of my head. was the original van bored out? or had any machining done to it?
Author:  Doc [ Thu Aug 21, 2008 12:29 pm ]
Run a compression test on the new engine and tell us the readings.
Did you do a final valve lash adjustment after getting it running?
Author:  Aggressive Ted [ Thu Aug 21, 2008 2:41 pm ]
Could be a retarded cam due to installation or a regrind without enough advance.
Author:  440_Magnum [ Thu Aug 21, 2008 3:05 pm ]
Post subject:  Re: no balls
Start with the basics- what's your ignition timing?
Author:  slantzilla [ Fri Aug 22, 2008 6:28 am ]
That was gonna be my first question too. When you're lost, go back to sqare one and check everything until you know where you are. The basics will kill you. :D
