It is currently Tue May 26, 2026 8:02 pm
 Post subject: Pinching the valve seals
PostPosted: Mon Aug 25, 2008 9:25 pm
Site Admin
At Medford I talked to Doc about my Mosquito reduction process during launch.
I will be popping the valve springs for an inspection of the seals, and failing damage to the seals, I'll pop the head loose to see what's going on with the guides.
With the spring and lift rates I've got, I may be pinching the seals and putting too much oil to the valve stems.
A quick look in the rear view on launch reveals I'm hiding the landing craft from the beach! Holy toledo Admiral!
If it's guides, my builder will be handling things. He told me he'd take care of the problem.
If the head comes off, I'll drop the ported head off my old race motor on there. Much smaller valves, but it'll get me by. So how much hose you putting to yours Tristan? :lol:
Next up is a heat shield that seals to the hood. I may build the hood scoop out to the nose of the car to catch some more pressure too. The way it's built, I'm afraid I put the intakes in a low pressure zone.
Fun stuff Wot? :D
CJ
PostPosted: Mon Aug 25, 2008 9:51 pm
Hi Ceej
Have a look at these air inlets - Image
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Mon Aug 25, 2008 11:07 pm
Site Admin
Now see, if I hadn't been trying for a cowl inlet, then changed to a front inlet, I'd be in great shape!
I've got the hood cut, and a top scoop started, so I'll take the easy way out and pull the air from the front of the hood.
The car is going away after this season, so I'll be looking for ideas that won't effect the look of the '63 GT. That hood I ain't cuttin'!
Fopar has a set of cold air intakes in his radiator support. He has a bit more to work with in his 53 Ford though. Once I get the radiator I picked up from SlantSixDan mounted, I may be limited as to where I can get some fresh O2 from!
Is that PVC, or something else?
CJ
PostPosted: Tue Aug 26, 2008 12:06 am
CJ
Enuff to stay in front of you and then drive the car home again :wink: !!
Even in moderation i am excessive!
PostPosted: Tue Aug 26, 2008 11:19 am
CJ
Well that could be anywhere from 20 to 100hp. :lol:
PostPosted: Tue Aug 26, 2008 11:34 am
CJ
Something else - ..this guy used ..........1 liter yogurt containers as a starting point - they are spun alloy these days - he raced like this for a season
Regards,
Fanie Gerber
PostPosted: Tue Aug 26, 2008 12:56 pm
Site Admin
CJ
Yep! It's just that close! The hooptie has reached it's acceleration pinnacle. I won't be doing anything more to go faster with it.
Next car! :D
Yogurt huh? :lol: That works!
CJ
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
