It is currently Mon Nov 09, 2026 4:22 pm
PostPosted: Mon Aug 18, 2008 7:52 am
Hello boys!! I need to connect a black wire to the "KEY SIDE" of the ignition coil ballast resistor or any other 12v service that is turned on and off by the ignition. This is power for an electric choke in a 64 Dart 225 slant 6. I can't decipher the electrical diagram and figure this out. Can any one help? :oops:
I'm a hot chick with a cool ride!
PostPosted: Mon Aug 18, 2008 9:37 am
Do you have a test light or voltmeter?
PostPosted: Mon Aug 18, 2008 10:44 am
Yes I do!
PostPosted: Mon Aug 18, 2008 3:22 pm
Do you see the Ballast resistor on the fire wall?
unplug the side with the brown wires, turn the key to "on" and check that connector for power, using your test light.
PostPosted: Mon Aug 18, 2008 5:05 pm
Yup, do as Doc says. Pull both connectors off the ballast resistor, turn the ignition key to the "on" position, and test for voltage in both connectors. Only one will have power. That's the one you want to hook the choke wire to.
PostPosted: Mon Aug 25, 2008 4:09 pm
Thank you so much for your help! Is one of these the ballast resistor or should I be looking for something else??? :?
See pics at:
http://dart1.shutterfly.com/
PostPosted: Mon Aug 25, 2008 4:15 pm
pretty certain this is the ballast
http://dart1.shutterfly.com/22
PostPosted: Mon Aug 25, 2008 4:57 pm
Yes, that is the ballast resistor.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: Thank you!!!!
PostPosted: Tue Aug 26, 2008 11:22 am
Awesome! You guys rock my world!!!! :D :wink:
