63 A Body Question
https://slantsix.org/forum/viewtopic.php?t=30779
Author:  lindross [ Thu Aug 28, 2008 5:46 am ]
Post subject:  63 A Body Question
I need help identifying the proper name of a body part that I think I'm missing. When I open up the passenger door, I can see the front tire? Is there a piece of sheet metal or something in the fender well that I'm missing? If so what is it and where can I find one?
Author:  Hemitym [ Thu Aug 28, 2008 7:15 am ]
The part you are probably missing is called, Shield, dash panel to fender part # 2254 804-5.
The code # from a 1963 collision parts list is 23-34-121.
You will probably need to start looking in wrecking yards, or ask around the forums such as this one.
Wayne
Author:  Hemitym [ Thu Aug 28, 2008 7:23 am ]
The correct # is 2242-442-3 for a Dart, the # in my post above is for a full size Dodge.
Wayne
Author:  lindross [ Thu Aug 28, 2008 8:26 am ]
Is it safe to assume the same piece listed for the Dart is the same for the Valiant? It's a 63 Valiant.
Author:  Dart270 [ Thu Aug 28, 2008 8:29 am ]
I believe they are the same, but not sure. I know you can swap a whole Dart front clip onto a Valiant and vice versa for 63-66 cars.
Author:  Hemitym [ Thu Aug 28, 2008 9:21 am ]
Yes they are the same for Dart & Valiant, Probably 63/64/65/66 are the same but I don't have the parts list for the years other than the 63.
Author:  lindross [ Fri Aug 29, 2008 6:59 am ]
Another A body question while I'm on a roll learnin and such. Can someone explain the difference between a 2 door hardtop and a 2 door coupe?? :?
Author:  Dart270 [ Fri Aug 29, 2008 7:41 am ]
Hardtop has no "B" pillar behind the door, while the sedan does. This makes the sedan lighter and stiffer, but people don't like the looks as much. Me, I like 4drs and 2dr sedans best.
I believe a hardtop and a coupe are exactly the same thing.
Author:  lindross [ Fri Aug 29, 2008 12:00 pm ]
Ok, so technically that would make mine the 2 door sedan then? Just struck me as odd to use the word sedan with a 2 door car. Mine is a 2 door with the B pillar behind the door (between front and back windows). I'm just trying to learn some of the correct terminology and as much as I can about my little Valiant. :)
Author:  6shotvanner [ Fri Aug 29, 2008 12:42 pm ]
I think it's just a matter of where somebody is raised up and who with 8) Around here if theres no frame around the top and back of the door glass it's a hardtop(two,four door an wagons)and the rest we called 2dr posts or 4dr sedans.Coupe now,40 Ford coupe wasn't a hardtop and my uncle had a 49 Ford Business Coupe and a 50 Ford 2dr sedan(Fords terms) and they were both posts.Since we're talking slants here I'd just call it,Good :lol:
