It is currently Sat Jun 06, 2026 11:39 am
 Post subject: Carb jetting slant turbo
PostPosted: Tue Sep 02, 2008 12:27 pm
:?: I recently finished fabrication/installation of my turbo system on my slant. The rest of the motor is stock and I am using a small air research T3 running 7psi of boost.
I could use some help setting up the carb. My car is a 75 dart sport, and the carb is the holley 1945 single barrel. I have the floats but am wondering if someone could recommend a jet size that would make a good starting point.
I myself have very little understanding of carb jetting, so my mechanic will perform all the adjustments, but he thought I should see what others had to say regarding, the jetting. Also any advice concerning timing would also be appreciated :?: thanks
PostPosted: Tue Sep 02, 2008 8:11 pm
i don`t have any exsperience with turbo`s but i would go 4 sizes up on the jet and keep total timing in the 12/15degs range and use champion 9y`s or r5674-6 ngk or 274 accel, to start with maybe colder if you start hurting plugs. if you have the peanut plug head then use rv9yc champion, br6fs ngk or 262 accels.
Users browsing this forum: Ahrefs [Bot] and 3 guests
