| Sticky valves https://slantsix.org/forum/viewtopic.php?t=30785 |
Page 1 of 2 |
| Author: | Damraider [ Thu Aug 28, 2008 11:51 am ] |
| Post subject: | Sticky valves |
I found a killer deal on a 65 Valiant the other day. It had been sitting in the garage for 28 years . They did not start it during this time. I have it home now, and got it to turn over, but bent 4 pushrods because those valves are stuck. Any magic treatment to free them up ( I'm trying penatrating oil now) or is it best to remove the head and do it right ( I know, I know, LOL !!) Thanks, Steve |
| Author: | pharmboy [ Thu Aug 28, 2008 12:06 pm ] |
I'd say that the 'best' way would be to remove the head and do things properly. But if you're a fan of all things quick/dirty, this might work. Get a brass or aluminum rod(or any metal softer than the steel the valves are made of) and drill one end so it's slightly cup shaped and will fit onto the tip of the valve stem. Make sure you're aligned with the valve, and give a few gentle taps with a 2lb hammer...or not so gentle if things don't want to yield. This may free things up, or may make removing the head necessary to remove bits of valvetrain. Either way, things are closer to being solved. Quick disclaimer: I make no claims at being any sort of expert/role model. If doing anything I do/recommend causes damage to you or your stuff, there will be no liability claims made against me. |
| Author: | Damraider [ Thu Aug 28, 2008 12:18 pm ] |
Quote: give a few gentle taps with a 2lb hammer...or not so gentle if things don't want to yield
LOL!! yes, I should have mentioned that was the first thing I did ( the redneck in me always says "hit first" , worry later). Any others ?
| Author: | Reed [ Thu Aug 28, 2008 12:19 pm ] |
Pull the valve cover and rocker arms. Replace the bent pushrods. Soak the whole valvetrain with some Marvel Mystery Oil. Let it soak for a couple hours. Return with a big rubber mallet. Whack the end of each valve with the rubber mallet until it moves. Reinstall the rocker arms and whack the rocker arms over the valves to verify the valves move. |
| Author: | pharmboy [ Thu Aug 28, 2008 12:41 pm ] |
Notice I did mention making a special tool to insure that the force was localized to the valve, and that the hammer has less of a chance of performing its natural function as sort of a divining rod for locating fragile/expensive car parts and thumbs... |
| Author: | Damraider [ Thu Aug 28, 2008 12:46 pm ] |
Thanks guys !! Did a search also and found a good write up by Dan ( imagine that !!) . Check out what $250.00 buys !! ![]() ![]() ![]()
| Author: | 68barracuda [ Thu Aug 28, 2008 1:17 pm ] |
COOL |
| Author: | 6shotvanner [ Thu Aug 28, 2008 3:18 pm ] |
Sweet deal |
| Author: | SlantSixDan [ Thu Aug 28, 2008 9:25 pm ] |
See this post. |
| Author: | digger12 [ Fri Aug 29, 2008 1:18 am ] |
| Post subject: | Re: Sticky valves |
Quote: I found a killer deal on a 65 Valiant the other day.
Looks a lot like my AP6...
Steve |
| Author: | pharmboy [ Fri Aug 29, 2008 6:07 am ] |
Quote: Sweet deal
So that's why the valves have those grooves in them...so the claw hammer can get a grip |
| Author: | 6shotvanner [ Fri Aug 29, 2008 8:49 am ] |
Sure is nice of MoPar to put them nice hooky groovy things in them valves for claw hammers |
| Author: | Damraider [ Fri Aug 29, 2008 10:35 am ] |
Two down , two to go . I went to a crow bar cause I broke my claw hammer and damn near killed myself flying off the car, LOL!!!! I bet my wife wishes that she would have done a backround check before commiting to marriage !! |
| Author: | Damraider [ Tue Sep 02, 2008 5:51 pm ] |
She RUNS and Drives now !! Thanks guys for all the support !! Took two days ,a couple of pushrods, two containers of penetrating oil, one broken hammer, one crowbar, two starters, and a little swearing , but I got them free and the engine actually purrs pretty nice. Changed out the master and the wheel cylinders and picked up some 14" rims and tires (Craigslist is the best) and took the family out for a cruise. My 11 year old son helped quite a bit and so did my daughter and wife. Thanks, Steve |
| Author: | Reed [ Tue Sep 02, 2008 5:57 pm ] |
One of my favorite stories in the old Slant Six News progressed along similar lines as yours. I believe it was Doctor Dodge who bought a 65 (66?) dart convertible out of a junkyard with a seized motor and detailed his trials and tribulations getting it running. First the motor was stuck, then it had stuck valves, then the carb was bad, finally the distributor was bad, but Doc got it running using parts on hand. Definitely keep us posted how this goes! |
| Page 1 of 2 | All times are UTC-07:00 |
