| Super Six carb to intake gasket question https://slantsix.org/forum/viewtopic.php?t=30791 |
| Author: | dusterguy225 [ Thu Aug 28, 2008 6:16 pm ] |
| Post subject: | Super Six carb to intake gasket question |
The carb rebuild kit (Walker) I bought only came with a 318 carb to intake gasket, not the super six carb to intake gasket. Will the 318 one work? |
| Author: | SlantSixDan [ Thu Aug 28, 2008 9:12 pm ] |
Please be specific. Which gasket arrived in your kit? Describe it for us, or post a (reasonably small) picture. How thick is it? Two round holes or one big bathtub-shaped hole? End notches or none? And (exactly) what carb are you using? |
| Author: | Guest [ Thu Aug 28, 2008 9:16 pm ] |
That's the one with the notches in the side, right? If so, i've had good luck using them as long as the surfaces are flat, and the carb is properly torqued-down and kept that way. I have not experienced vacuum leaks in the notch areas, however others may have. |
| Author: | dusterguy225 [ Fri Aug 29, 2008 2:13 pm ] |
I am using a Carter BBD. The 318 one in this pic is the one I have. Its about 1/2" thick, give or take. |
| Author: | SlantSixDan [ Fri Aug 29, 2008 2:21 pm ] |
You ought to be OK using the notched gasket. |
| Author: | dusterguy225 [ Fri Aug 29, 2008 2:24 pm ] |
Quote: You ought to be OK using the notched gasket.
Thanks! |
