DANA 60
https://slantsix.org/forum/viewtopic.php?t=3080
Author:  max roth [ Tue Jan 08, 2002 2:40 pm ]
Post subject:  DANA 60
How do you identify a DANA 60 rearend? Im pretty sure its a 14 bolt rear cover, but are there any numbers to differentiate between a 60,70,and a 80?
madmax6995@hotmail.com
Author:  Tim Keith [ Tue Jan 08, 2002 5:58 pm ]
Post subject:  Re: DANA 60
try this link
: How do you identify a DANA 60 rearend? Im
: pretty sure its a 14 bolt rear cover, but
: are there any numbers to differentiate
: between a 60,70,and a 80?
axles spotters guid
tkeith@mindspring.com
Author:  mark dingbaum [ Wed Jan 09, 2002 12:22 pm ]
Hi,
I'm pretty sure the Dana 60 has a 10 bolt cover...
There is a big "60" cast into the lower right (viewed from cover side) web (from near cover to near right tube), that will tell you if its a 44 or 60, not sure if the 70 and 80 have the same casting mark.
good luck,
mark
mldingba@collins.rockwell.com
Author:  kairosman [ Thu Jan 10, 2002 9:44 am ]
From what I remember, the 70 has it cast in there somewhere too. It has been a while since I climbed underneath my dad's truck, but I think I remember seeing it. I may get a chance to check this weekend depending on what he drives. Just curious though- what will this be going behind?
: Hi,
: I'm pretty sure the Dana 60 has a 10 bolt
: cover...
: There is a big "60" cast into the
: lower right (viewed from cover side) web
: (from near cover to near right tube), that
: will tell you if its a 44 or 60, not sure if
: the 70 and 80 have the same casting mark.
: good luck,
: mark
glovert@southwestern.edu
Author:  max roth [ Mon Jan 14, 2002 12:40 pm ]
: From what I remember, the 70 has it cast in
: there somewhere too. It has been a while
: since I climbed underneath my dad's truck,
: but I think I remember seeing it. I may get
: a chance to check this weekend depending on
: what he drives. Just curious though- what
: will this be going behind?
this will be going behind a 440 an a 4 gear. My friend lokes my turbo idea so hes going to jerk the slant six out of his 65 Belvedere and drop in 440 and stick a couple turbos on it. I figure with the torque it will make a Dana might be in order.
Author:  kairosman [ Mon Jan 14, 2002 7:47 pm ]
Yup, dana might be a good call there. Sounds neat. Tell us where we can see some of his pics if he posts them-even if it isn't a slant.
: this will be going behind a 440 an a 4 gear. My
: friend lokes my turbo idea so hes going to
: jerk the slant six out of his 65 Belvedere
: and drop in 440 and stick a couple turbos on
: it. I figure with the torque it will make a
: Dana might be in order.
