It is currently Mon Nov 23, 2026 3:16 am
 Post subject: lokar throttle cable
PostPosted: Fri Aug 29, 2008 11:31 am
Ive got this throttle cable from lokar. I cant figure out how it connects to the pedal. It has a ball just like the old stock cable, but then it has a weird end and I dont know how to connect the cable to the pedal Heres the link to a picture.
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Fri Aug 29, 2008 11:32 pm
You pull the cable out of the housing, take the clevis off, and put the cable back in the housing. Then you use the ball end just like a stock cable.
The carb end has a small set screw in it that you have to loosen to get off. The the cable pulls right out.
You also want to cut the housing to length with the cable pulled out, and cut the cable after you've made all your brackets, etc.. :D
PostPosted: Sat Aug 30, 2008 3:56 pm
Oh ok thanks. That makes sense.
Ronnie
