Timing belt topic
https://slantsix.org/forum/viewtopic.php?t=30809
Author:  zerglin87 [ Fri Aug 29, 2008 10:25 pm ]
Post subject:  Timing belt topic
okay, i was told that the timing belt and gears had "nylon" in them, please discuss about them?
Author:  Reed [ Fri Aug 29, 2008 10:27 pm ]
(1) Slant sixes do not use timing belts. Slant sixes use a camshaft gear, a crankshaft gear, and a timing chain.
(2) Factory original timing gears had nylon coating the teeth f the gears. THis wears off and causes slack in the tiing set of the motor.
(3) Replacement timing sets do not use nylon teeth.
Author:  daniel_depetro [ Sat Aug 30, 2008 5:04 am ]
Is there anywhere that sells true roller timing chains for the slant six?
Author:  rock [ Sat Aug 30, 2008 5:09 am ]
Post subject:  yeh, double roller, too. I have one I don't need now
Yep,
THe best are double roller. I have one new i n the box I don't need. PM me if you want it and a pic of it.
rock
'64d100
Author:  daniel_depetro [ Sat Aug 30, 2008 7:38 am ]
What brand is it?
How much are you asking?
Does the /6 have it's own specific timing set or does it sare a set with the small blocks, big blocks, or any other vehicles set-up?
What manufactures produce a double row roller timing set for the /6?
Author:  zerglin87 [ Sat Aug 30, 2008 7:40 am ]
(1) same purpose.
(2) known.
(3) known.
still i just want to know how long it takes to replace such a nylon ..system..thingy. i heard its $30 for the replacement timing set, dunno yet, i was just suggested to replace it. I never replaced a timing chain, but i have a good ideas as to how to do it.
Author:  DusterIdiot [ Sat Aug 30, 2008 7:54 am ]
Post subject:  an afternoon
It will take an afternoon to change, and more if you decide to do any 'optional' work... like 'degree in the cam' rather than 'line up the
dots'... and how you seal up the timing cover and how careful you are in sealling the front oil pan gasket.
Author:  Greg Ondayko [ Sat Aug 30, 2008 7:52 pm ]
Post subject:  Re: an afternoon
And that can be the hardest part of this job.
