| Once in a while knock https://slantsix.org/forum/viewtopic.php?t=30845 |
Page 1 of 2 |
| Author: | 86slantram [ Sun Aug 31, 2008 9:14 pm ] |
| Post subject: | Once in a while knock |
So, every once in a while my slant knocks. It always starts fine, and takes a minute or two. As soon as it starts, I shut it down. Wait a minute or two and it starts up w/o a problem, no knocking again for months on end. This has happened once before. Whats up? |
| Author: | SlantSixDan [ Sun Aug 31, 2008 10:04 pm ] |
How many miles are on this engine? What grade of engine oil are you using, and what brand and type of oil filter? |
| Author: | 86slantram [ Sun Aug 31, 2008 10:21 pm ] |
77k but unsure if original. I use 10w30 with a NAPA Gold filter. |
| Author: | Aggressive Ted [ Sun Aug 31, 2008 10:23 pm ] |
Try the NAPA 1806 filter and your problems may go away. The filter has a full length internal stand pipe so the filter will stay full of oil, for a no knock start up. |
| Author: | SlantSixDan [ Sun Aug 31, 2008 10:27 pm ] |
Your oil choice sounds fine, and the NAPA Gold filters are of good quality. As Ted says, the #1806 filter does indeed do a better job of holding oil in the filter after shutdown, ready for next startup. But given that you're already using a good-quality filter and not something cruddy like a Fram, you may want to service the oil pressure relief valve, too, in case it is dirty and jammed partway open (or occasionally sticking partway open), bleeding off pressure and causing slow buildup and knocking on startup. See thread 1, thread 2. |
| Author: | Joshie225 [ Sun Aug 31, 2008 10:32 pm ] |
Do you mean the engine starts up fine and then doesn't start knocking until a minute or two has passed? Can you tell us the year and model of your vehicle? If it's a 1986 Ram pickup as your user name suggests does have computerized ignition and a feedback carburetor? |
| Author: | 86slantram [ Mon Sep 01, 2008 8:42 am ] |
Yes, as my name states, I have an '86 Ram. Computerized ignition? Check. Feedback Carb? Huh? Not sure about that one. I know that the engine is largely stock (except for a k & n airfilter). |
| Author: | Eric W [ Mon Sep 01, 2008 9:37 pm ] |
Don't rule out the fuel pump making a deep knock-like sound. Mine does sometimes. |
| Author: | 86slantram [ Thu Sep 04, 2008 6:37 pm ] |
I bought a Napa 1806 filter. Guys at NAPA said it was for farm implements, and I know the / was used in a variety of applications. Is this right? Long, white, but with less flow than the 1068 I normally buy. Will the loss of flow effect the pump? |
| Author: | emsvitil [ Thu Sep 04, 2008 6:40 pm ] |
If you have an automatic, check the tightness of the bolts on the flex plate. |
| Author: | 86slantram [ Thu Sep 04, 2008 6:45 pm ] |
Its a 4 speed manual, so the flex plate is out. |
| Author: | SlantSixDan [ Thu Sep 04, 2008 6:53 pm ] |
Quote: I bought a Napa 1806 filter. Guys at NAPA said it was for farm implements, and I know the / was used in a variety of applications. Is this right? Long, white, but with less flow than the 1068 I normally buy. Will the loss of flow effect the pump?
Who says it has less flow? I don't believe that's correct. It'll fit and work well on your slant-6.
| Author: | 86slantram [ Thu Sep 04, 2008 7:17 pm ] |
The rep at NAPA claims less flow. Thanks for all the advice. |
| Author: | 86slantram [ Sat Sep 06, 2008 4:40 pm ] |
So, I have installed the 1806 filter and cleaned the relief valve. Engine knocked at first, then went silent. Let the truck run a while, shut it off. Checked the oil, let it cool. Went out to start it again, knocking is back. What to you guys think? WTF is wrong now? |
| Author: | SlantSixDan [ Sat Sep 06, 2008 5:07 pm ] |
The "rep" (parts-ringer-upper) at NAPA is making stuff up. Did you service the oil pressure relief valve per the links further up this thread? |
| Page 1 of 2 | All times are UTC-07:00 |
