| Exhaust flanges on feeBay https://slantsix.org/forum/viewtopic.php?t=30866 |
Page 1 of 2 |
| Author: | stonethk [ Tue Sep 02, 2008 7:01 am ] |
| Post subject: | Exhaust flanges on feeBay |
I came across this auction and was wondering if NE1 had any experience with these pros/cons etc. http://tinyurl.com/5cxqro |
| Author: | SlantSixDan [ Tue Sep 02, 2008 9:44 am ] |
eBay link posting guidelines and instructions are here. |
| Author: | Reptile Dysfunction [ Sun Sep 07, 2008 3:34 am ] |
Sweet, just what I need to make a set of zoomies for the Reptile Dysfuntion rat. (I hate that rat rod term but everyone uses it) |
| Author: | slantzilla [ Sun Sep 07, 2008 12:26 pm ] |
Not real fond of the stainless, but I'm gonna try to get a set of the mild steel ones. |
| Author: | gmader [ Sun Sep 07, 2008 12:42 pm ] |
I would be VERY interested, except, I have not figured out the rectangular tubing that would attach to the flanges, and I really haven't figured out the rectangular to round transitions needed to make this work. |
| Author: | slantzilla [ Sun Sep 07, 2008 12:47 pm ] |
Quote: I would be VERY interested, except, I have not figured out the rectangular tubing that would attach to the flanges, and I really haven't figured out the rectangular to round transitions needed to make this work.
All my headers have a square port in the flange. They just use an expander thingy to make the round pipe fit the square hole. |
| Author: | gmader [ Sun Sep 07, 2008 1:12 pm ] |
Do muffler shops have rectangular swages? that would make it simple. |
| Author: | stonethk [ Sun Sep 07, 2008 1:54 pm ] |
Yeah the mild steel ones look like the way to go I guess he posted those after. My nubishness is showing here but am I correct in assuming these are used as a clamp-type fit holding the header flange to the head, or is there welding involved? |
| Author: | slantzilla [ Sun Sep 07, 2008 2:18 pm ] |
Quote: Yeah the mild steel ones look like the way to go I guess he posted those after.
The pipes are welded into the flange. This is basically the starting point of a "do-it-yourself" header kit.My nubishness is showing here but am I correct in assuming these are used as a clamp-type fit holding the header flange to the head, or is there welding involved? I need some for the Daytona. My Clifford's and Hooker's won't even come close to fitting in it. |
| Author: | sandy in BC [ Sun Sep 07, 2008 5:55 pm ] |
A wooden swage would work fine with these. ......around here a chunk'o'birch would be the thing..... |
| Author: | CARS [ Sun Sep 07, 2008 5:58 pm ] |
Quote: eBay link posting guidelines and instructions are here.
What exactly is the problem with copying a link and pasting it?? Seriously Dan, you must have something else to do than to find fault in everything |
| Author: | Joshie225 [ Sun Sep 07, 2008 6:57 pm ] |
The problem is when you post a giant unbroken line it makes the formatting for the whole thread wide enough to fit that line. Unless you have a large high resolution monitor the thread then requires scrolling left and right to be read. Read and heed please. |
| Author: | Fopar [ Mon Sep 08, 2008 10:01 am ] |
When I made my headers, Put the tube in a vice squeezed them down to the width needed - then put a C clamp on the flattened side- rotated the tube 90 degeres and squeezed the tube to the other dimension. That left the tubes with 4 flattened sides with 4 nice radiuses in the corners. |
| Author: | gmader [ Mon Sep 08, 2008 10:31 am ] |
Fopar, you are a genius! Thanks for the help on how to thing about the problem. |
| Author: | Guest [ Mon Sep 08, 2008 11:13 am ] |
Quote: The problem is when you post a giant unbroken line it makes the formatting for the whole thread wide enough to fit that line. Unless you have a large high resolution monitor the thread then requires scrolling left and right to be read.
Really? I've read this forum on several different computers with different sized monitors...and it just word wraps the links automatically. Must be an IE thing I guess, since I use IE.
| Page 1 of 2 | All times are UTC-07:00 |
