| Lapping compound https://slantsix.org/forum/viewtopic.php?t=30918 |
| Author: | ceej [ Thu Sep 04, 2008 11:29 am ] |
| Post subject: | Lapping compound |
There's a good possibility I'll be pulling my head this weekend. Doc, you suggested a lapping compound for touching things up before reassembly. I spaced the name/brand you suggested. Could you share it again here? Thanks! CJ |
| Author: | 68barracuda [ Thu Sep 04, 2008 11:41 am ] |
I knew You had some screws loose but it is not necessary to go THAT far |
| Author: | Doc [ Thu Sep 04, 2008 12:02 pm ] |
Clover lapping compound. See this link for info and the different grades: http://www.newmantools.com/clover.htm DD |
| Author: | ceej [ Thu Sep 04, 2008 3:02 pm ] |
Thanks Doc! For this application I would think 320 would be the stuff. Is that what you would use? CJ |
| Author: | Fopar [ Thu Sep 04, 2008 3:30 pm ] |
I've got some, see you this weekend. |
| Author: | Doc [ Thu Sep 04, 2008 3:44 pm ] |
The 320 "Fine" compound works great. You should not need a lot to get the impression you need to see full seat contact. If the valve angles are off, your machine shop should correct the problem. DD |
