"After Market" A/C
https://slantsix.org/forum/viewtopic.php?t=30938
Page 1 of 1
Author:  dusterguy225 [ Fri Sep 05, 2008 5:56 pm ]
Post subject:  "After Market" A/C
I just had a thought, Could I use the stock A/C compressor hoses, etc. but use an after market (vintage air, southern air, etc.) under dash heat/cool unit like this or this?
What year A/C compressors, and other A/C equip. would work?
My heater core is shot, and I would like A/C, but cant find a whole origional under dash unit for a 73+ A-Body.
Author:  Charrlie_S [ Fri Sep 05, 2008 7:35 pm ]
Post subject:  Re: "After Market" A/C
Yes, use the stock factory underhood components, and have new hoses made up to fit.
Author:  dusterguy225 [ Fri Sep 05, 2008 7:50 pm ]
What about mounting the new heat and A/C box, what do I have to do?
Author:  65 dartman [ Sat Sep 06, 2008 3:43 am ]
Any idea who makes new hoses or can make copies of original hoses?
Author:  Charrlie_S [ Sat Sep 06, 2008 5:42 am ]
Mounting of the heat/A/C unit requires fabrication work, with custom mounting brackets.
You do not want copies of the original hose, they will not fit the aftermarket evaporator. Any full service A/C shop should be able to fab custom hoses. I do that on a regular basis.
Author:  Guest [ Sat Sep 06, 2008 10:43 am ]
This place has complete in-dash/under-dash kits:
www.nostalgicairparts.com
I haven't tried one, but I am probably going to eventually use the under-dash kit.
Author:  dusterguy225 [ Sat Sep 06, 2008 7:12 pm ]
How would you hook up an under dash unit? Bolt it to the dash?
Another question, what compressors/parts could I use for this? I am on kind of a budget, and I know 73-76 A/C parts are pretty hard to find, and I could pick up a complete set from a junk yard for about $50 out of, lets just say, a chevy or somthing.
