| LONG ROD? https://slantsix.org/forum/viewtopic.php?t=3106 |
| Author: | jyri eramaa [ Sun Jan 13, 2002 1:37 pm ] |
| Post subject: | LONG ROD? |
i saw in a machine shop longer rods that the ones in 198 cid...they are 20cm!!! from center to center..the piston pin is floating with a bushing...22 mm aproximately. the rod was 3 cm wide fronm the bottom. looked good quality, with good bolts etc. you can find these from JAGUARS...if you can use that long rod in a de-stroked 225? for what? i do not know, but it seems like you actually could find a better quality long rod maybe from a european engine...? have to investigate. actually i could need a rod that is in midlle of 198 & 225 rod...do you know any that would suite a 225 crank?? jyri.eramaa@jwt.fi |
| Author: | Doctor Dodge (Doug Dutra) [ Mon Jan 14, 2002 9:36 pm ] |
| Post subject: | Re: Long Connecting Rods for the SL6 |
The big problem with finding other rods to fit a SL6 is that the SL6 crank pin (rod journal) is real wide. It measures right around 1.210 inches so someone do the math, that 3 cm (or 30 mm) rod may be wide enough and 20 cm long, that almost 8 inches! Are they forged steel? Trouble is that I don't see many Jag engines in the junk yards around here! DD Quote:
: I saw in a machine shop longer rods that the : ones in 198 cid...they are 20cm!!! from : center to center..the piston pin is floating : with a bushing...22 mm aproximately. : the rod was 3 cm wide from the bottom. : : looked good quality, with good bolts etc. : : you can find these from JAGUARS...if you can : use that long rod in a de-stroked 225? : for what? i do not know, but it seems like you : actually could find a better quality long : rod maybe from a european engine...? have to : investigate. : : actually i could need a rod that is in midlle : of 198 & 225 rod...do you know any that : would suite a 225 crank?? |
| Author: | Jesse Lackman [ Tue Jan 15, 2002 12:18 pm ] |
| Post subject: | Re: LONG ROD? |
There are others; Chevy (big block?) 6.813 long 2.315 large end bore 1.429 width forging # 3835274, 3835324, 3835609, 3701890 The width can be cut down no problem. --------------------------------------------- rvsrchjl@westriv.com |
| Author: | Dart270 [ Tue Jan 15, 2002 1:34 pm ] |
: There are others; : : Chevy (big block?) : 6.813 long 2.315 large end bore 1.429 width : : forging # 3835274, 3835324, 3835609, 3701890 : : The width can be cut down no problem. : --------------------------------------------- I've seen 7"+ long rods for modified BB Chevy too, but I've never tried them. J&M engine dynamics in Nebraska, or Cox Bros in Ohio can get you custom hipo rods too. Cheers, Lou madsenl@its.caltech.edu |
| Author: | jyri eramaa [ Tue Jan 15, 2002 2:59 pm ] |
: The big problem with finding other rods to fit : a SL6 is that the SL6 crank pin (rod : journal) is real wide. It measures right : around 1.210 inches so someone do the math, : that 3 cm (or 30 mm) rod may be wide enough : and 20 cm long, that almost 8 inches! : Are they forged steel? : Trouble is that I don't see many Jag engines in : the junk yards around here! : DD i have to ask... i would think so...if im right the jag has a 4.2 liters engine??? was it so, that could be ... and it has over 200 hp in stock... e-type? have to check. jyri.eramaa@jwt.fi |
