It is currently Sun Nov 29, 2026 4:12 am
PostPosted: Tue Sep 16, 2008 10:14 am
OK, here's the setup, you experts straighten me out.
I did a search and can't quite get the answer.
66 Dart wagon, maual steering box out of a 64, Disc brake setup out of a 73 Duster, C-body tie rod ends.
What pitman arm and Idler arm do I use?
PostPosted: Tue Sep 16, 2008 10:19 am
A '63-'66 pitman arm is what you need so if the one on the '64 steering box is good use it.
