It is currently Sun May 10, 2026 3:28 am
PostPosted: Tue Oct 28, 2008 3:27 pm
Is there a bolt on front sway bar available for the 68 Dart? (4 wheel drums). I have read some posts that mentiond welding. Unfortunatly I don't weld and don't know anyone who does.
PostPosted: Tue Oct 28, 2008 3:28 pm
Addco.
I have F/R Addco bars on my 64.
PostPosted: Tue Oct 28, 2008 5:12 pm
Check out these guys:
http://www.justsuspension.com/product/338
This bar can be found at other suppliers for a lot more dough.
PostPosted: Tue Oct 28, 2008 7:38 pm
The Just Suspension bar is made by Addco and is a lot cheaper through Just Suspension.It is a bolt on unit and works well,I have one on my Daughters 72 Valiant.
HyperValiant
PostPosted: Tue Oct 28, 2008 7:41 pm
I run a 1 1/8" bar from them. I had to drill a hole in both lower control arms to bolt the angled pice on that the links hook to. Feeding it through the K frame was the hardest part....takes maybe an hour and a half to put it in. Of course this is for a B body, so an A body will be different, but not much.
PostPosted: Tue Oct 28, 2008 11:28 pm
Good to know that there are some that bolt on and that no welding will have to be done to get it on! I need one of those on the '72 Valiant....
-1972 Valiant-
'72 Valiant
PostPosted: Wed Oct 29, 2008 1:02 am
Makes a big difference...handles better, tracks down the road better. If you get one locate the angle pieces that go on the control arm so the bend nest under the upper lip on the control arms. Doing this will help keep them in place.
PostPosted: Wed Oct 29, 2008 5:34 am
I've had a set, front and rear of ADCO's on my '74 since 1985. I got mine from JC Whitney and they are all bolt in and work fine. I dont know the diameter but for everday driving they are fine, a little bigger would be nice though.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
