It is currently Wed May 13, 2026 12:16 am
PostPosted: Mon Sep 22, 2008 11:39 am
I have a daily driver that is getting a bad howling in the rear gear set. I tore it down on Friday and there are no obvious bearing problems or bad wearing of the ring and pinion. Well, since it is tore down I have been thinking this is a great time to add the gear ratio that I thought should be in it anyway.
If you look in Jegs, Summit, Etc. They sell the name brand gear sets and "their" gear sets usually for about $40.00 less than the name brand sets.
Do you think that the machining is better in the higher priced sets?
Is this a case of getting what you pay for??
And if so, what do you think is the quietest brand name out there???
Chris'
Autobody
Restoration
Service
