It is currently Sat Nov 21, 2026 10:02 pm
 Post subject: Cam question
PostPosted: Sun Sep 21, 2008 4:55 pm
I was wondering what the best cam would be for a 225 stock bore, 1brl carb, pollished head, gasket matched, 904 street/strip shift kit, 3.55 rear gears, 2 1'4 exhaust.
Image75 dart custom, 225, >10.5-1, hurricane, 500holley, erson cam, 904, 8.8 ford 3.55 or 3.91 aussielocked, 17" steelies, and much more.
PostPosted: Sun Sep 21, 2008 5:13 pm
I apologize for the off topic here but how come you chose to keep the 1-bbl. carb.?
I would think at this point you'd notice a pretty big gain by switching to a 2-bbl. set-up (or a small 4-bbl.).
1969-1/2 Dodge Super Bee A12 (440 Six Pack, 4-spd, Dana 60)
1974 Plymouth Duster 360 (4-spd, 8.75")
1973 Plymouth Duster (225, auto, 8.25")
2001 Dodge Ram 1500 QC 2wd (5.9L, auto, Dana 60)
PostPosted: Sun Sep 21, 2008 5:15 pm
the erson reverse pattern cam seem to be the stock replacement cam some like, i would go with at least a .450lift and 260degs dur with stock compression.
PostPosted: Sun Sep 21, 2008 5:38 pm
For now i am keeping the 1brl because of money issues.
I have a two brl intake and that will be next. I also forgot to mention Head is shaved .090
PostPosted: Sun Sep 21, 2008 6:20 pm
Erson 270 cam Great street cam.
My02
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Sep 22, 2008 7:32 pm
Will that cam help with more low end torque?
PostPosted: Tue Sep 23, 2008 5:52 am
More torque and will really wake your 90 off shave.
You will like it.
Frank
PS remember you can still get in on the group buy.
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Sep 23, 2008 10:37 am
The Erson RDP cam design is designed for a SL6 that has intake side "limitations". (like a 1 bbl carb and no head porting)
The RV15 (260 Intake) - 295 (244 Ex) is about as far as you should go if you stick with the 1bbl carb.
