It is currently Thu Sep 17, 2026 12:36 am
 Post subject: 1968 Charger a833 swap
PostPosted: Sun Sep 21, 2008 6:30 pm
Hi,
I'm changing out the 904 auto in my Charger to an overdrive a833. It came originally with a 3 speed manual, so all the pedals are there. Not sure why it was converted to an automatic.
I've got a 7 1/4 rear, so my driveshaft is too long. Can I get one from another car, or should I just have mine shortened? I've got the factory manual, and reading it showed the v8 and 8 3/4 shafts were shorter, maybe one would work?
Thanks!
John D
1968 Dodge Charger 225 a833 OD
1962 Valiant 170 2 door post car
1962 Valiant Signet (junker right now)
1962 Valiant Signet, one owner car, waiting for me to pick it up. Scratch that-got it!
 Post subject: So...
PostPosted: Sun Sep 21, 2008 6:42 pm
The 3 speed manual of that time period was a non-synchro 1st gear, that didn't last long... later in the early 70's the full synchro box was placed behind 383-2v cars, and survived just fine... The A-904 probably was a cheap, easy to get item, and easy enough to slide in...
Now comes the next question... why is your driveline too short? Is the A-833OD you are putting in from an A/F body (short tranny), or a Truck?
If the A-904 was a shorty, and you're using a truck tranny, then I could understand (you might just need to grab a driveline out of a 1975-1978 Cordoba to make that one work...)...
Once you make the conversion, keep an eye out for a better rearend for your car... the OD with the weight of your car will prefer gearing in the 3.5 to 3.9 range a bit better (your car probably has 3.23's which is a good start)...depending on your driving style your 7 1/4" may not last long... :wink:
Good Luck, glad to see a great B body that is staying with it's original option.... :D
PostPosted: Mon Sep 22, 2008 12:08 pm
Thanks DI,
The driveshaft is too long because the OD tranny is longer than the original three speed, not too short. I figure about three and a half inches too long.
I've never done anything like this so I'm learning as I go. As to recommending a cordoba for a longer shaft, should I try an A-body car for a shorter shaft? Is there a list or chart online? I'm looking now but haven't found one yet.
I am so excited about the slant six. I'll be able to have the body style I've been in love with since I was 14 and be able to keep gas in it. :D Also I'll be able to fly on the freeway. My last charger had 3.91s with an automatic and it was screaming on the freeway.
Thanks again!
John D
PostPosted: Mon Sep 22, 2008 1:49 pm
You may just want to check locally and see if there's a driveshaft shop in your area. Here in Dallas, there are several shops that shorten/rebalance driveshafts for a reasonable price.
vm
PostPosted: Mon Sep 22, 2008 3:15 pm
Driveshaft lengths: http://www.autohobbydigest.com/tables.p ... _slip_yoke
 Post subject: Uh no...
PostPosted: Mon Sep 22, 2008 7:06 pm
the cordoba could have an 8 1/4 or 9 1/4" rear which would require a driveline a couple inches shorter than yours is... if you gotta lose 3" or more... it's time to look into a drive line company... to bad you weren't local I used to have a couple of Cordoba drivelines from big block/727 equipped cars which might have been short enough...
good luck,
-d.Idiot
PostPosted: Tue Sep 23, 2008 4:44 am
:oops: I figured a cordoba would have a longer driveshaft.
My factory service manual gives the length of my driveshaft as 58.27 inches and 2.75 inch diameter. The 68 dart shaft for a 7 1/4 rear and auto or 3 speed manual trans is listed as 54.36 and 3 inch diameter, a difference of 3.91 inches. We figured on about 3.5 based on tape measure measurements. Does this seem close enough? Also is this a valid way to figure it?
there is a local dart parts car for sale and I'm hoping the shaft is available. There is also a 68 valiant parts car on craigslist here locally. The shaft ought to be the same on it right?
Josh, thanks for the link. I'm going to study it well.
Thanks!
John
