It is currently Mon Nov 23, 2026 7:19 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Cylinder Head
PostPosted: Thu Jan 24, 2002 3:50 am
Hello, I have a 63 block, 63 head, and two other heads a 72 and 74.I've spent some time practice porting on the 74 and now have another head not sure of the year but it has the redesigned valve cover and air pump tube. Is this a good head to spend time and money on?
Thanks Drew 63GT
MoparBrat63@aol.com
 Post subject: Re: Cylinder Head
PostPosted: Thu Jan 24, 2002 9:44 am
: Hello, I have a 63 block, 63 head, and two
: other heads a 72 and 74.I've spent some time
: practice porting on the 74 and now have
: another head not sure of the year but it has
: the redesigned valve cover and air pump
: tube. Is this a good head to spend time and
: money on?
: Thanks Drew 63GT
The redesigned valve cover is the '80+ head. I'd spend time on the '72 or '74 heads. Best compression chamber.
PostPosted: Thu Jan 24, 2002 8:00 pm
: money on?
: Thanks Drew 63GT
Here is some additional info on the SL6 head differences.
SL6 Head Article Link
