| Linda's '63 Dart GT https://slantsix.org/forum/viewtopic.php?t=31426 |
| Author: | ceej [ Tue Sep 30, 2008 9:00 pm ] |
| Post subject: | Linda's '63 Dart GT |
The GT was to be my new race car, but Linda has fallen for the little bugger, so it's now her new car! There will be some adjustments to it's build. I have a 170 project that started out in Josh's stable. It will likely be the new power plant for the Dart. With the 198 Crank, I will use the '74 Transmission, and send the pushbutton control back for modification to operate it. The car is pretty straight, and suffers from little rust. So here's the basic starting point. Linda and THOR had an adventure fetching the car from it's hiding place under a Tree. It found it's way to our side yard for a bit, under our own tree. ![]() It's pretty rough inside. ![]() ![]() I pushed the car around into the driveway to get it cleaned up and start stripping it for body and paint. ![]() ![]() And started removing things this evening. ![]() ![]() The trunk ![]() And the remains of the mat. ![]() Much left to do. But it's a start! CJ |
