| Block ? https://slantsix.org/forum/viewtopic.php?t=3145 |
| Author: | MrMopar [ Mon Jan 21, 2002 6:08 pm ] |
| Post subject: | Block ? |
Hi Guys I've got 3 blocks to chose from for my rebuild don't know the years but 2 have 5 freeze plugs 1 has 3 is one better than the other? each has a crank I "think" 2 are cast and one is steel I think the later block is the steel crank Thanks for any help mrmopar@greganti.com |
| Author: | Doctor Dodge (Doug Dutra) [ Mon Jan 21, 2002 7:19 pm ] |
| Post subject: | Re: Which SL6 Block ? |
: Hi Guys : I've got 3 blocks to chose from for my rebuild : don't know the years but 2 have 5 freeze : plugs : 1 has 3 is one better than the other? each has : a crank I "think" 2 are cast and : one is steel I think the later block is the : steel crank. Read through the artilce on SL6 Blocks. <A HREF="http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm">http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm</A> I would go for the 5 freezeplug, forged steel crank one. DD SL6 Block & Prep info. article |
