dics brakes
https://slantsix.org/forum/viewtopic.php?t=3147
Author:  andrew wagner [ Tue Jan 22, 2002 2:24 pm ]
Post subject:  dics brakes
hey guys I just got a dics brakes setup from a 72 duster. Can I use the spindle from that on my car 69 dart? the spindle is the only difference in the suppension that I can see or am I missing something.
andrew wagner
Author:  Doc. [ Tue Jan 22, 2002 3:12 pm ]
Post subject:  Re: dics brakes
: hey guys I just got a dics brakes setup from a
: 72 duster. Can I use the spindle from that
: on my car 69 dart? the spindle is the only
: difference in the suppension that I can see
: or am I missing something.
: andrew wagner
If the 72 is the 4 piston "fixed position" calipers then yes, change everything from the spindle on out. You will need 14 inch wheels to clear the disc caliper and a disc brake porportioning valve will need to be added to "balance" the front to rear braking force.
Author:  andrew wagner [ Tue Jan 22, 2002 3:24 pm ]
yes!!!!!!!!!!!!!! thank you I was begining to think I messed up and bought the wrong thing.
thanks again!!!!!!!!!!!!!!!!!!!
andrew wagner
: If the 72 is the 4 piston "fixed
: position" calipers then yes, change
: everything from the spindle on out. You will
: need 14 inch wheels to clear the disc
: caliper and a disc brake porportioning valve
: will need to be added to "balance"
: the front to rear braking force.
: DD
Author:  Dart270 [ Tue Jan 22, 2002 4:23 pm ]
: yes!!!!!!!!!!!!!! thank you I was begining to
: think I messed up and bought the wrong
: thing.
: thanks again!!!!!!!!!!!!!!!!!!!
: andrew wagner
Dics brakes?? Sounds painful...
madsenl@its.caltech.edu
Author:  andrew wagner [ Wed Jan 23, 2002 4:03 pm ]
: Dics brakes?? Sounds painful...
: Lou
my back is killing me!!!!!!!!!!!!!!!
andrew
