Oil Pump replacement
https://slantsix.org/forum/viewtopic.php?t=31478
Author:  HookedByA62Valiant [ Fri Oct 03, 2008 8:03 pm ]
Post subject:  Oil Pump replacement
Can someone explain the process of replacing a slant six oil pump?
I found a Melling 66C for $20 and am thinking about doing it myself. But I've never done this before. It looks like a couple of bolts, a gasket and putting it in the right spot.
Thanks.
Author:  6shotvanner [ Fri Oct 03, 2008 8:46 pm ]
Thats about it,5 bolts(old ones had 6) clean the block real good,use some gasket goo on the pump/gasket(keep it from moving wilst installing).Wouldn't hurt to use some assembly lube on the gear,install in reverse order of removal,pour a little oil in before install an rotate the gear some make sure it's lubed and a bit more after install.I don't use gasket goo on the block side.Good luck
Author:  6shotvanner [ Fri Oct 03, 2008 8:54 pm ]
Oh yeah and 200 inch pounds of torque :wink:
Author:  THOR [ Fri Oct 03, 2008 9:42 pm ]
Not to mention that unless it's in a truck, you will need to undo the motor mounts and raise the engine quite a bit to get clearance to pull it out.... unless the motor is already out. :D
~THOR~
Author:  HookedByA62Valiant [ Sat Oct 04, 2008 8:06 am ]
Post subject:  Thanks gentlemen, you Rock!
Well, sounds like a bone head like me can handle that. :lol:
Author:  Fopar [ Sat Oct 04, 2008 9:29 am ]
You might want to check with Doc about the drive gear on the new pump most of them are soft and will get chewed up.
