| buildin a 68 dart 4dr and have found a 74 barracuda partscar https://slantsix.org/forum/viewtopic.php?t=31481 |
| Author: | 4.20 [ Fri Oct 03, 2008 9:53 pm ] |
| Post subject: | buildin a 68 dart 4dr and have found a 74 barracuda partscar |
is the cuda a " A-body" I believe it is but can't find a listing for all the body styles. will the parts from a 74 barracuda fit my 68 sedan dart? Thinking this would be a good disc brake, 8" rear end conversion with a driveshaft (I'm planning on a 225->318 conversion and already have BB torsion bars). Don't think the engine has run in years so I don't think I'd get any other parts out of it (int. is shot). is it worth tryin to get??? Thanks for the help cheers |
| Author: | 4.20 [ Fri Oct 03, 2008 9:54 pm ] |
that should be Barracuda, sorry |
| Author: | THOR [ Fri Oct 03, 2008 10:10 pm ] |
If it is a '74 barracuda, then no, it't not an A-body. IIRC the last year for the A-body barracuda was '69. Then they moved to the larger E-Body platform. Unless you accidentally typoed and it's a '64 Barracuda. I'm not sure exactly what parts will swap, but I can't imagine there being very many that do. ~THOR~ |
| Author: | DusterIdiot [ Fri Oct 03, 2008 10:50 pm ] |
| Post subject: | Disc Brakes... |
Quote: I'm not sure exactly what parts will swap
The 73 and 74 E-body used the same spindle and hardware (calipers, discs), that the 1973-1976 A-body did... transmission, engine, EI, almost everything else is a for that platform only...for the price these days an E-body hulk will fetch the same price as a really nice A-body....sadly -D.Idiot |
