It is currently Wed Nov 18, 2026 12:41 pm
PostPosted: Tue Sep 02, 2008 7:01 am
I came across this auction and was wondering if NE1 had any experience with these pros/cons etc.
http://tinyurl.com/5cxqro
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
PostPosted: Tue Sep 02, 2008 9:44 am
eBay link posting guidelines and instructions are here.
PostPosted: Sun Sep 07, 2008 3:34 am
Sweet, just what I need to make a set of zoomies for the Reptile Dysfuntion rat. (I hate that rat rod term but everyone uses it)
PostPosted: Sun Sep 07, 2008 12:26 pm
Not real fond of the stainless, but I'm gonna try to get a set of the mild steel ones. :D
PostPosted: Sun Sep 07, 2008 12:42 pm
I would be VERY interested, except, I have not figured out the rectangular tubing that would attach to the flanges, and I really haven't figured out the rectangular to round transitions needed to make this work.
PostPosted: Sun Sep 07, 2008 12:47 pm
All my headers have a square port in the flange. They just use an expander thingy to make the round pipe fit the square hole. :D
PostPosted: Sun Sep 07, 2008 1:12 pm
Do muffler shops have rectangular swages? that would make it simple.
PostPosted: Sun Sep 07, 2008 1:54 pm
Yeah the mild steel ones look like the way to go I guess he posted those after.
My nubishness is showing here but am I correct in assuming these are used as a clamp-type fit holding the header flange to the head, or is there welding involved?
PostPosted: Sun Sep 07, 2008 2:18 pm
The pipes are welded into the flange. This is basically the starting point of a "do-it-yourself" header kit.
I need some for the Daytona. My Clifford's and Hooker's won't even come close to fitting in it. :?
PostPosted: Sun Sep 07, 2008 5:55 pm
A wooden swage would work fine with these. ......around here a chunk'o'birch would be the thing.....
PostPosted: Sun Sep 07, 2008 5:58 pm
What exactly is the problem with copying a link and pasting it?? Seriously Dan, you must have something else to do than to find fault in everything :lol:
Chris'
Autobody
Restoration
Service
PostPosted: Sun Sep 07, 2008 6:57 pm
The problem is when you post a giant unbroken line it makes the formatting for the whole thread wide enough to fit that line. Unless you have a large high resolution monitor the thread then requires scrolling left and right to be read.
Read and heed please.
PostPosted: Mon Sep 08, 2008 10:01 am
6 Pack Dart
When I made my headers, Put the tube in a vice squeezed them down to the width needed - then put a C clamp on the flattened side- rotated the tube 90 degeres and squeezed the tube to the other dimension. That left the tubes with 4 flattened sides with 4 nice radiuses in the corners.
PostPosted: Mon Sep 08, 2008 10:31 am
Fopar, you are a genius!
Thanks for the help on how to thing about the problem.
PostPosted: Mon Sep 08, 2008 11:13 am
Really? I've read this forum on several different computers with different sized monitors...and it just word wraps the links automatically. Must be an IE thing I guess, since I use IE.
