no e brake on my 64 gt
https://slantsix.org/forum/viewtopic.php?t=31498
Author:  MiDi [ Sun Oct 05, 2008 1:08 am ]
Post subject:  no e brake on my 64 gt
well i actually found somthing wrong with my car.....
no e-brake! u pull it and it feels normal but no stop
whats up and what should i look for, can i swap cables from my 73 over?
i really think an e brake is important so this conserns me.
thanks as always guys and gals
Author:  THOR [ Sun Oct 05, 2008 2:05 am ]
Needs adjustment most likely. There threaded adjusters inline on the cable going back IIRC, you can simply adjust them up from there. Either that, or your rear brakes need to be drastically adjusted.
Could also be that the cable is broken/missing. Not sure if the 73 cable would swap, but I cant see an reason why it wouldn't.
~THOR~
Author:  slantzilla [ Sun Oct 05, 2008 3:09 am ]
My '66 had completely different cables than my '76 Duster did under the floor. The ones from the frame into the drums may be interchangeable. :shock:
Author:  gmader [ Sun Oct 05, 2008 7:21 am ]
the cables are different lengths in different years/models, and may not interchange easily. I found out the hard way, when I tried to use duster cables in my 1965 plymouth.
If you need to repair your cables, I had good luck with a marine rigging shop. Find out where the sailboaters up there get their rigging done, and they can probably fix the cables for you.
Author:  wjajr [ Mon Oct 06, 2008 6:02 pm ]
The lever that attaches to the brake shoe that the cable pulls on to set the brake may have become disconnected. This happened to my car when I did not properly crimp the little "C" clip that fixes the lever to the shoe. Yea, it was a dumb guy moment.
Wouldn't hurt to pull the drums and take a look, and readjust the rear shoes.
Author:  MiDi [ Mon Oct 06, 2008 7:51 pm ]
Post subject:  thanks!
thanks for the advice, i'll check that out.
yeah we are pulling everything and checking everything out when it's up on the lift. tomorrow is the front brake & master cylinder swap and exhaust work. wendsday will be the steering box and torsion bar swap.
nice yellow dart btw!
Author:  wjajr [ Tue Oct 07, 2008 5:55 am ]
Thanks MiDi, I call it Sponge Bob.
