Master Cylinder re-location adapter
https://slantsix.org/forum/viewtopic.php?t=31554
Page 1 of 1
Author:  DadTruck [ Tue Oct 07, 2008 6:18 pm ]
Post subject:  Master Cylinder re-location adapter
To make an intake manifold conversion fit into the engine bay on this 83 D-150 I may need to move the master cylinder / brake booster over, maybe a couple of inches. Any info on a master cylinder kit / adapter to help this along?
thanks
Author:  Joshie225 [ Tue Oct 07, 2008 6:30 pm ]
The only car that used anything close were the 1968 Hemi Barracudas and Darts and they didn't move the master cylinder that much. They were also for the 4-bolt master cylinders. My '74 D100 Club Cab had manual brakes. Would getting rid of the booster get you enough clearance? Have you done a mock-up to see how much clearance you need? Are you dead set on using this particular manifold?
Author:  DadTruck [ Tue Oct 07, 2008 7:15 pm ]
not dead set on that intake, but it could work well, I agree the mock up is the next step,
Author:  slantzilla [ Wed Oct 08, 2008 6:36 am ]
There is a guy on www.moparts.com who sells an adapter to move the master over some. It also uses the later 2 bolt aluminum master. IIRC, his name is GregZ, or maybe Zippy.
Author:  DadTruck [ Wed Oct 08, 2008 4:14 pm ]
thanks much,, I'll check it out
Author:  volaredon [ Thu Oct 09, 2008 7:44 pm ]
exactly WHAT inake setup are you wanting to use? If it's on your truck, I can't imagine that space would be a problem, with a /6 and any manifold you'd wanna use. the ones I've worked on, you could practically climb inside the eng compartment, to work on the engine.
Author:  DusterIdiot [ Thu Oct 09, 2008 8:53 pm ]
Post subject:  Long Ram
If he has power brakes and the Hpak manifold it's pretty close to the front of the master cylinder in a truck... if it had manual brakes, it's a no prob deal....
Author:  illldeca [ Thu Oct 09, 2008 9:07 pm ]
i wouldnt move the master cylinder. it its pretty big engine bay under the hood of my d150 and i could just cut a slot in each of the engine mounts and move the engine over atleast 6inches just my idea though donno if it would work. :idea:
edit: that might impact the placement of the drive shaft for the rear end
