| supercharged slant https://slantsix.org/forum/viewtopic.php?t=31617 |
| Author: | theslantingsix [ Fri Oct 10, 2008 2:59 pm ] |
| Post subject: | supercharged slant |
hey i am building a supercharged slant is but i have one question about pistions what pistons should i use becouse a while back on here i read bout a turbo slant and all his pistons ended up in his oil pan so i want to avoid that and i am gonna go about 8-9 psi of boost and also what else should i know about superchargers thanks josh |
| Author: | Shaker223 [ Fri Oct 10, 2008 4:50 pm ] |
Stock pistons will work fine if you keep the afr correct. |
| Author: | theslantingsix [ Fri Oct 10, 2008 5:01 pm ] |
well i am gonna have to bore it some couse it smokes Whats the afr |
| Author: | Shaker223 [ Fri Oct 10, 2008 6:32 pm ] |
Air fuel ratio = AFR |
| Author: | bigslant6fan [ Sun Oct 12, 2008 8:06 am ] |
200,000 mile stock pistons + hone,re-ring,re-bearing + 10LBS of boost + CORRECT AFR = no problems. |
| Author: | Greg Ondayko [ Tue Oct 14, 2008 8:07 pm ] |
What afr Should one Shoot for under boost? 14.7? 13? 12? Thanks, Greg |
| Author: | Shaker223 [ Wed Oct 15, 2008 5:12 am ] |
Around 11.5:1 under boost conditions. |
| Author: | slantzilla [ Wed Oct 15, 2008 2:39 pm ] |
I think from reading this thread, pistons are the least of your worries. |
| Author: | turboram [ Thu Oct 16, 2008 11:55 am ] |
I tend to run 10.5 or as rich as possible under boost without sacrificing power. the rich mixture cools the air charge and pistons. my luck has been if its not as rich as possible than just the wrong conditions cause lean afr and pistons go by by. but maybe thats just my luck? or that every other motor I've blown hasn't been a /6. they do seem to take allot more abuse than anything else |
