| I finally lashed the valves and now I have a high speed miss https://slantsix.org/forum/viewtopic.php?t=31643 |
| Author: | bwhitejr [ Sun Oct 12, 2008 6:41 am ] |
| Post subject: | I finally lashed the valves and now I have a high speed miss |
I lashed the valves on my CompCams 252S cam (factory settings 0.010/0.012) to 0.010 and 0.015. The idle is nice, but now I have a high speed miss. It feels like a spark plug is grounding out. This only happens under load and heavy acceleration. I just want to confirm whether it is rrelated to the valve lashing or not. bwhitejr |
| Author: | SlantSixDan [ Sun Oct 12, 2008 8:05 am ] |
I would look elsewhere for this problem — I think if it were lash-related, it would be more uniform across all cylinders. If it feels like an ignition fault, it probably is! |
| Author: | slantzilla [ Sun Oct 12, 2008 9:15 am ] |
If it wasn't there before you adjusted the valves, it is most likely related to what you did. Make sure you didn't knock a plug wire loose. Possibly a tight valve. |
