| 500 cfm carb? https://slantsix.org/forum/viewtopic.php?t=3174 |
| Author: | Lew VB [ Mon Jan 28, 2002 7:28 pm ] |
| Post subject: | 500 cfm carb? |
I currently have a Holley 390 carb on my /6, the carb is in need of rebuilding. Would the Edlebrook 500 be a good replacement or rebuild the Holley? It is a '66 from a Barracuda. It has the Offy Alum intake, Clifford Headers, and a Crane 720791 cam. It is in a '41 Dodge 1/2 ton Military 4x4 with a 4.89 rear end ratio, 35" tall tires and a 904 Auto Tranny. What a combo, huh. Any input would be helpful. Lew VB |
| Author: | Doctor Dodge (Doug Dutra) [ Tue Jan 29, 2002 11:14 pm ] |
| Post subject: | Re: How Many RPMs to Red Line? |
The 390 should be enough to get you to 5000 RPM given your set-up. Go with the 500 if you want to rev it higher then that. DD Quote:
: I currently have a Holley 390 carb on my /6, : the carb is in need of rebuilding. Would the : Edlebrook 500 be a good replacement or : rebuild the Holley? It is a '66 from a : Barracuda. It has the Offy Alum intake, : Clifford Headers, and a Crane 720791 cam. It : is in a '41 Dodge 1/2 ton Military 4x4 with : a 4.89 rear end ratio, 35" tall tires : and a 904 Auto Tranny. What a combo, huh. : : Any input would be helpful. : Lew VB |
| Author: | Lew VB [ Wed Jan 30, 2002 5:21 pm ] |
: The 390 should be enough to get you to 5000 RPM : given your set-up. : Go with the 500 if you want to rev it higher : then that. : DD I shift the auto tranny at 4000-4500 rpm when I'm "cleaning out the carbon". 60 mph is about 3100 rpm in drive. I guess I wondering if the 500cfm carb would be to much at the low end and it would gag when I stand on it from an idle. The turbo thing interests me and I'm thinking in a couple of years when I get done with the rest of the truck, I might explore the possibilities of a turbo and the 500 would lend itself to that pretty good, maybe? Thanks for the help. Lew VB |
