It is currently Thu Nov 19, 2026 11:25 pm
 Post subject: Windshield washer
PostPosted: Tue Oct 28, 2008 5:25 pm
My squeeze bulb windshield washer doesn't work. When I press down it back flows into the washer tank. The lines are clear. Is there a back flow prevention valve? Where is it? I would assume at the tank but can't find it. I hate the thought of having to change to electric. Cannot find a parts source.
Richard
PostPosted: Tue Oct 28, 2008 5:33 pm
I've never seen this type of washer.
But if the hoses are the size of aquarium air line hoses, I'd think you could get a airline check valve and put it in somewhere to fix things up.
Get the rubber flapper kind........
PostPosted: Tue Oct 28, 2008 5:39 pm
yes, the check valve is hanging open. i wouldnt give mine up either. an inline check valve could probably be retrofitted to the inlet line, but ensure your nozzles are clear.
PostPosted: Tue Oct 28, 2008 6:10 pm
Thanks for the quick postfor the quick post
Where is it located?
Richard
