Turn Signals
https://slantsix.org/forum/viewtopic.php?t=31759
Page 1 of 2
Author:  dusterguy225 [ Fri Oct 17, 2008 8:55 pm ]
Post subject:  Turn Signals
I my way home from work tonight, my turn signals broke, :( but in a wierd way. They are solid now and do not even blink. They worked about 2 mi up the road from my house, and now they don't. No light is out, just when I turn the turn signals on, its just a solid green arrow and solid lights on the out side. None of them even blink! :shock:
Please healp!
Author:  SlantSixDan [ Fri Oct 17, 2008 9:01 pm ]
Replace the turn signal flasher.
Author:  dusterguy225 [ Fri Oct 17, 2008 9:06 pm ]
Wow, it went out just like that?
Whats a good replacement? And, forgive my stupidity, where it it located? Is it that round silver thing under the dash?
Author:  THOR [ Sat Oct 18, 2008 12:25 am ]
If you found the round silver thing, then there it is. Do the hazards work?
Do as Dan says (sounds like a T.V. show doesn't it?) and replace it. I suggest getting an electronic one from your friendly parts store. They are about 5-6 bucks on average, and will draw alot less current than the old Bi-metal units. Plus... you get that new car "clicking" sound.
W00t..
~THOR~
Author:  dusterguy225 [ Sat Oct 18, 2008 4:21 am ]
Thanks guys! :D I will go an get one today.
Author:  SlantSixDan [ Sat Oct 18, 2008 6:59 am ]
Yep, electronic. Ideal or Tridon #EL-12C. It's in a see-through plastic can instead of metal.
Author:  dusterguy225 [ Sat Oct 18, 2008 2:21 pm ]
Thanks a lot guys! :D
Author:  dusterguy225 [ Sat Oct 18, 2008 3:35 pm ]
I just got my new flasher, still no signals! :( My emergency flashers work, but not the turn signals. Any suggestions? Is there a fuse?
Author:  Mike'68Dart [ Sat Oct 18, 2008 6:04 pm ]
There should be 2 flashers. One for the emergency and one for the turn lights
Mike
Author:  dusterguy225 [ Sat Oct 18, 2008 7:14 pm ]
Oh... I guess I found the emergencys then! :oops: Where might the turn lights flasher be?
Author:  Mike'68Dart [ Sat Oct 18, 2008 7:24 pm ]
Well, mine is under the dash close to the glove box, kinda between the heater controls and the glove box itself. This is in a '68 Dart.
Mike
Author:  dusterguy225 [ Sat Oct 18, 2008 7:32 pm ]
I will go out and check this right now!
Author:  Mike'68Dart [ Sat Oct 18, 2008 7:35 pm ]
Good luck!! White cars RULE!!!
Author:  dusterguy225 [ Sat Oct 18, 2008 7:50 pm ]
Thanks, and hell yea!
It worked!!! You are a genious! Thanks a lot! I have turn signals now!!!
Author:  Mike'68Dart [ Sat Oct 18, 2008 7:53 pm ]
No problem, Glad I could help.
Mike
Page 1 of 2 All times are UTC-07:00
