It is currently Tue Nov 17, 2026 2:35 pm
PostPosted: Tue Nov 11, 2008 5:09 pm
I just ordered me a set of Remflex gaskets yesterday. Should help get rid of my vac and exhaust leaks. Problem is, I can't find replacement inter-manifold bolts anywhere. My local Chrysler dealer lists them NFA. Anyone see a problem with using studs instead of bolts? I'm 99% sure I won't be able to re-use the ones in there now as I made the current ones up myself (extended the threads on a pair of hardware store bolts.) and I'm certain I'm gonna have trouble just getting them out, let alone re-use them. What do you folks think?
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Tue Nov 11, 2008 5:14 pm
Studs are fine. Infact, alot of the manifold stacks had the stud instead of a bolt on the passenger side of the carb. I like them better than the bolts personally, as they have better clamping ability that a bolt.
Hence why head studs are a better solution than head bolts.
What I (as well as many others I am sure) is use a chunk of D8 all-thread (on the driver side of the carb), and use nuts with lock washers on each end. Others can elaborate on the whereabouts of such an item, since I usually get mine from them, and as such, don't need to find it myself most of the time.
~THOR~
Users browsing this forum: Amazon [Bot] and 6 guests
