It is currently Tue Nov 17, 2026 10:05 pm
 Post subject: 4 bbls got me mad
PostPosted: Sun Oct 19, 2008 5:01 pm
hey guys i got a offy from the recent buy and now i need some help chooseing the carb.
i got three choices and am open to sugestions
i am thinkin ether
A: 390 holley
B: 470 holley truck advenger
C: 525 road demon jr
i want tuneabilty, good power,good low end, eletric choke, low budget cost (round 350)
but i am going crazy trying to get it right
thanks josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Sun Oct 19, 2008 5:35 pm
1 vote for a 390 Holley here. :D
PostPosted: Sun Oct 19, 2008 5:57 pm
holley 390 since its the smaller carb
To many damn dodges and now a slant
PostPosted: Sun Oct 19, 2008 5:58 pm
400 or 500 CFM Carter AFB. harder to find, but WAY easier to tune than a Holley. Less prone to gas leaks too. Alternatively, you could build an adapter plate and mount a two barrle on there. That would be my recommendation for cheapness, ease of tuning, and low end torque.
PostPosted: Sun Oct 19, 2008 6:35 pm
I am using the 525 Demon on my car. I was attracted to the features like center hung floats, metering blocks, 4 corner idle, etc. Also thought my car might go faster with more CFM. Had to send the carb back to BG twice to fix mis alligned throttle plates and metering block leaks. Works fine now, gets great gas milage.
Doesn't seem to perform better than the 500 Holley 2 barrel I used to run, that one is actually a 375CFM in 4 barrel terms. That must be enough for a high performance street machine, so go with the 390 Holley. It is always best to keep the venturies as small as possible consistent a stong top end. You'll have to settle for a metering plate and single inlet to stay in your price range though. Good luck.
PostPosted: Sun Oct 19, 2008 6:47 pm
well if i ever needed to go 2 bbl i could just go to my super six i got stashed in the barn someware
PostPosted: Sun Oct 19, 2008 9:59 pm
Eddy 500,period.1801 Thunder series,easy to tune, adjustable secondarys.What can I say other than I'll never fight with a Holley again,at least not on a slant :wink:
PostPosted: Sun Oct 19, 2008 11:27 pm
My box stock Holley 390 works pretty well on my stock cammed '67 vintage 225. The idle has gone down hill a bit lately so I think it's time to open it up and clean it out. If one could buy a new 400 CFM AFB I'd go for that. My last Holley 390 worked well on my hotter 225 also. If someone would loan me an Eddy 500 I'd try it, but I'm not going to go buy one.
The primary venturis of the list 8007 390 Holley 4 bbl are 1 1/16". This is smaller than even the list 7448 350CFM Holley 2bbl which is 1 3/16". This draws more on the main circuit which is reflected in the 51 primary jet of the 390 and the 61 jet of the 350 2bbl. Having a stronger signal typically means better metering performance which leads to improved response and economy. This is why I'm running the 390 instead of a 350 or 500 CFM Holley 2bbl.
PostPosted: Mon Oct 20, 2008 12:39 am
Any carb can be made to run on a slant, my 600 is too big by nit picker standards but it runs well on street, Very well on highway and puts up good numbers at the track! You have to be willing to tune the carb, not just turn the idle screws. Four barrels are for race cars if you want a street car get a 2 bbl and have at it!
TF
Even in moderation i am excessive!
PostPosted: Mon Oct 20, 2008 6:14 am
For the most part we've been pretty happy with the Holley 390's. With that said we're gonna pull it off the Valiant this winter and use a Quadrajet. We're thinking we will get some better fuel mileage and a bit better drive ability. Only time will tell if our thoughts hold true or not. Stay tuned for news at 11:00.
Linder Tech.com
Bubba's Trailer Park
PostPosted: Mon Oct 20, 2008 6:23 am
I didn't know you could get a 500 AVS from Edelbrock.
PostPosted: Mon Oct 20, 2008 8:07 am
My vote is 500 Eddy. Great right out of the box.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Oct 20, 2008 9:28 am
Another choice is the 450 CFM spreadbore Holley 4360 economaster carb. You would wire the secondaries shut or have them open later. This carb gives me great performance and good gas mileage in my Ford van (351W), but should work okay on a slant too.
PostPosted: Mon Oct 20, 2008 10:29 am
I'm curious to learn your results. I have a tricked up Q-Jet and thought I'd try it, but then I laid the spreadbore gasket on my Offy and Clifford manifolds and did not like the huge overlap. The throttle bores ended well outside the standard opening and I don't have the hood clearance for a big adapter.
PostPosted: Mon Oct 20, 2008 10:38 am
Rug_Trucker,yup EDL-1801 pg.13 latest Summit cat.,$345.95.Frank is right, good to go straight from the box 8) Reed,wouldn't that spread bore need an adapter? I'm thinking the Offy manifold is set up for square bore like my Clifford.Don't know just how much the "spread" is on that 4360 econo.but might be an option.
