It is currently Fri May 15, 2026 6:30 am
PostPosted: Wed Oct 22, 2008 7:42 am
Hello All,
I'm planning my conversion to a dual reservoir master cylinder, but staying with drums all the way around (for now) and using the original junction block.
Since I can run my rear brake line straight from the m/c, am I right in thinking that I could use the spare port (that used to go to the rear brakes) on the junction block for the brake light pressure switch?
Thanks for any input.
Bill
'60 Dodge Dart Pioneer
Vivian
PostPosted: Wed Oct 22, 2008 11:51 am
Yep, that'll work. Changing to a mechanical brake light switch is even better, but more work.
