| Smoke from breather https://slantsix.org/forum/viewtopic.php?t=31857 |
| Author: | jmccabe [ Fri Oct 24, 2008 9:48 am ] |
| Post subject: | Smoke from breather |
my breather on my valve cover is like smoking i think and you can see small streams of oil going down from it. any help? |
| Author: | KBB_of_TMC [ Fri Oct 24, 2008 9:52 am ] |
I'd start by checking that your PCV is working OK - if the valve or hose gets plugged up, you can easily build up pressure and blow oil out of every hole. |
| Author: | jmccabe [ Fri Oct 24, 2008 11:56 am ] |
| Post subject: | Breather |
okay thanks. could it b that i just need a new breather? |
| Author: | SlantSixDan [ Fri Oct 24, 2008 12:06 pm ] |
No, it's not that you need a new breather. If the PCV system is working and hooked up correctly and you still get a high volume of smoke out the breather, it means your engine is mechanically whipped (excessive blowby). |
| Author: | coconuteater64 [ Fri Oct 24, 2008 12:21 pm ] |
Oh wow! I did a google search for "Slant six breather" and came up with this link. http://www.slantsix.com/UBB/Forum6/HTML/000412.html Sad to say I read about 6 pages of it and it got waaaaay off topic! But to answer the question, I concur that blow-by will cause the breather to smoke. Did it on my old LTD and it turned out to be a cracked oil ring. |
| Author: | Charrlie_S [ Fri Oct 24, 2008 5:25 pm ] |
[quote="coconuteater64"]Oh wow! I did a google search for "Slant six breather" and came up with this link. http://www.slantsix.com/UBB/Forum6/HTML/000412.html Sad to say I read about 6 pages of it and it got waaaaay off topic! quote] Man, is that thread still floating around out there. That had to be the longest, wierdest thread in the history of the internet. |
| Author: | dusterguy225 [ Fri Oct 24, 2008 7:53 pm ] |
Quote: Man, is that thread still floating around out there. That had to be the longest, wierdest thread in the history of the internet.
Yea, it was started in 02 and ran untill 06 and is like 85 pages long. Wow! |
| Author: | Eric W [ Fri Oct 24, 2008 9:49 pm ] |
Quote: No, it's not that you need a new breather. If the PCV system is working and hooked up correctly and you still get a high volume of smoke out the breather, it means your engine is mechanically whipped (excessive blowby).
What Dan said. Do a compression test and see if any cylinders are low....like below 50. Been there, done that, did an engine swap.
