It is currently Wed Nov 18, 2026 3:23 am
 Post subject: Smoke from breather
PostPosted: Fri Oct 24, 2008 9:48 am
my breather on my valve cover is like smoking i think and you can see small streams of oil going down from it.
any help?
225 Slant Six [Super Six]
PostPosted: Fri Oct 24, 2008 9:52 am
I'd start by checking that your PCV is working OK - if the valve or hose gets plugged up, you can easily build up pressure and blow oil out of every hole.
 Post subject: Breather
PostPosted: Fri Oct 24, 2008 11:56 am
okay thanks. could it b that i just need a new breather?
PostPosted: Fri Oct 24, 2008 12:06 pm
No, it's not that you need a new breather. If the PCV system is working and hooked up correctly and you still get a high volume of smoke out the breather, it means your engine is mechanically whipped (excessive blowby). :-(
PostPosted: Fri Oct 24, 2008 12:21 pm
Oh wow! I did a google search for "Slant six breather" and came up with this link. http://www.slantsix.com/UBB/Forum6/HTML/000412.html Sad to say I read about 6 pages of it and it got waaaaay off topic! :shock: Really weird!!
But to answer the question, I concur that blow-by will cause the breather to smoke. Did it on my old LTD and it turned out to be a cracked oil ring.
PostPosted: Fri Oct 24, 2008 5:25 pm
[quote="coconuteater64"]Oh wow! I did a google search for "Slant six breather" and came up with this link. http://www.slantsix.com/UBB/Forum6/HTML/000412.html Sad to say I read about 6 pages of it and it got waaaaay off topic! :shock: Really weird!!
quote]
Man, is that thread still floating around out there. That had to be the longest, wierdest thread in the history of the internet. :lol: :lol:
PostPosted: Fri Oct 24, 2008 7:53 pm
Yea, it was started in 02 and ran untill 06 and is like 85 pages long. Wow! :shock:
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Fri Oct 24, 2008 9:49 pm
What Dan said. Do a compression test and see if any cylinders are low....like below 50. Been there, done that, did an engine swap.
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
