| Tore out my slant the other day, good enough for a rebuild? https://slantsix.org/forum/viewtopic.php?t=31903 |
| Author: | dusterguy225 [ Sun Oct 26, 2008 8:42 pm ] |
I say go for it. I can't wait to rebuild mine! I also have a reman block, but I don't know any thing else about it. it has some #s on it, but thats it. |
| Author: | moparfreak77 [ Mon Oct 27, 2008 4:47 am ] |
I have been wondering about the fact that its been turned and bored. I want to spend the least possibe on machine work. what should i look for tearing it down? |
| Author: | 66aCUDA [ Mon Oct 27, 2008 7:13 am ] |
Moparfreak77 It will most likely be ok. That being said you will need to keep you fingers crossed as your Mains & Rod bearings are allready at 30 under. You can go more its just tough finding the bearings. Stock type pistons and rings can be found to 60 over. As for planeing the deck or head have the shop clean up both and then measure both and see where you are. My 02. Frank |
| Author: | moparfreak77 [ Wed Oct 29, 2008 8:25 pm ] |
How do I know what the crank journals should measure? "have the shop clean up both and then measure both and see where you are." Measure what? |
| Author: | 66aCUDA [ Thu Oct 30, 2008 6:42 am ] |
Sometimes the journals dont need turned just honed. Easyest to let the shop look at it after its cleaned up. You CAN get smaller id bearing but its harder to find them. Frank |
