| 225 build https://slantsix.org/forum/viewtopic.php?t=31908 |
| Author: | turboram [ Mon Oct 27, 2008 7:39 am ] |
| Post subject: | 225 build |
I can't stop thinking about building a race slant! help! I need to know what parts to build a stout bottom end for a 225.as far as I can tell the only forged crank is in the 76 and older blocks, and there is nothing after market am I right? also I'm going with a long rod motor and I need 8-9:1 compression.I don't think the wisco set will do, don't like machining pistons as it needs as thick as possible top and a tall ring land. will 2.2 pistons hold a ton of boost or should I have cutom ones built?has there been a mls gasket built yet? Thanks for any help as I'll need it because it will most likely get broken as I won't stop pushing it till I get 1000hp. yes I have a sickness and the only cure is more power. Nick |
| Author: | 66aCUDA [ Mon Oct 27, 2008 7:46 am ] |
Turboram I would have Wisco do a custom piston with there new rods. MLS gasket is made in Australia and currently available. Forged crank is plenty strong just choose a good piece. Good luck and keep us posted Maybe start a new thread in the Gallery section. FRANK |
| Author: | turboram [ Mon Oct 27, 2008 7:59 am ] |
Thanks thats what I wanted to know. My local bone yard has a 225 in a 74 for 50$ i'll go get it and start building for next year |
| Author: | Dart270 [ Mon Oct 27, 2008 9:21 am ] |
Frank, Where is the MLS gasket from Australia available? I have heard a couple of rumors, but no knowledge of these. MLS is different (another ballpark better) from the nice composition ones I brought in a couple of years back. Thanks, Lou |
