87 truck timing marks indictate what timing amount?
https://slantsix.org/forum/viewtopic.php?t=31917
Author:  kafer65 [ Mon Oct 27, 2008 2:00 pm ]
Post subject:  87 truck timing marks indictate what timing amount?
I have a lean burn /6 that I will be converted to Electronic Ign. The stock distributor isn't adjustable but I did put a timing light on it but I don't know what the marks mean. I get a little advance at idle and it goes off the chart at light throttle and then goes to zero advance with a heavier foot. Weird. It runs well except for off idle transition hesitation and lack of power when the advance goes away. I've done a search but haven't found anything describing the timing units associated with the marks.
________
CR480
Author:  66aCUDA [ Mon Oct 27, 2008 4:44 pm ]
To go from lean burn to regular EI you will need to get another distributor(EI). SSDan has a source for these with a good curve all ready to go in.
Then you will need to go HEI or Mopar control module with an assoc. Harness.
It a fairly easy conversion.
Frank
Author:  SlantSixDan [ Mon Oct 27, 2008 4:48 pm ]
Old Car Parts Northwest for a new distributor.
Author:  kafer65 [ Tue Oct 28, 2008 7:31 am ]
I'm able to make out 20 near the left most end and there is a 10 and a 0 near the pickup mount. I may be getting more like 35 right off idle. I'me trying to exhaust my local options for a dissy right now.
________
hemp marijuana
