| Windshield washer https://slantsix.org/forum/viewtopic.php?t=31943 |
| Author: | RCFravel [ Tue Oct 28, 2008 5:25 pm ] |
| Post subject: | Windshield washer |
My squeeze bulb windshield washer doesn't work. When I press down it back flows into the washer tank. The lines are clear. Is there a back flow prevention valve? Where is it? I would assume at the tank but can't find it. I hate the thought of having to change to electric. Cannot find a parts source. |
| Author: | emsvitil [ Tue Oct 28, 2008 5:33 pm ] |
I've never seen this type of washer. But if the hoses are the size of aquarium air line hoses, I'd think you could get a airline check valve and put it in somewhere to fix things up. Get the rubber flapper kind........ |
| Author: | steponmebbbboom [ Tue Oct 28, 2008 5:39 pm ] |
yes, the check valve is hanging open. i wouldnt give mine up either. an inline check valve could probably be retrofitted to the inlet line, but ensure your nozzles are clear. |
| Author: | RCFravel [ Tue Oct 28, 2008 6:10 pm ] |
Quote: yes, the check valve is hanging open. i wouldnt give mine up either. an inline check valve could probably be retrofitted to the inlet line, but ensure your nozzles are clear.
Thanks for the quick postfor the quick postWhere is it located? |
