Help with valves for slant head
https://slantsix.org/forum/viewtopic.php?t=31974
Author:  mopardemon71 [ Thu Oct 30, 2008 8:41 am ]
Post subject:  Help with valves for slant head
Ok I got 1.72 chebbie valves now 11/32 stem single lock for the intake does anyone know what valve would be the next size up in diameter? I'm thinking 1.80 area but some where I saw a 1.78 valve.
Author:  SlantSixDan [ Thu Oct 30, 2008 8:51 am ]
1.77" & 1.44" valves from Engnbldr.
Author:  Joshie225 [ Thu Oct 30, 2008 9:34 am ]
Actually the Engnbldr intake is 1.70". 1.72 is actually a pretty good size. Going larger may not help and may even hurt performance.
Author:  Charrlie_S [ Thu Oct 30, 2008 10:15 am ]
The valves enginebldr lists for the slantsix are 3/8 stem. Mopar demon stated he has 11/32 stem valves, now, that means he has 11/32 guides.
I would contact engnbldr, and see if he has any 11/32 stem valves that would work. Also there is probably, a valve from a chevy distributer that will work.
Author:  Shaker223 [ Thu Oct 30, 2008 10:26 am ]
You can always have the valve turned down to fit your application too.
Author:  Doc [ Thu Oct 30, 2008 10:55 am ]
There is a 3/8 stem Mopar BB exhaust valve at 1.74 and an oversize at 1.80
I have used these as intake valves on Slants.
As noted, you do not really need to go that big in order to get good flow.
Author:  Dart270 [ Thu Oct 30, 2008 12:02 pm ]
SBC 1.72 valves work very well. SB Ford 1.78s are a good step up, but not necessary for most bore sizes and builds.
Author:  slantzilla [ Thu Oct 30, 2008 2:38 pm ]
The bigger size valves flow real good on a flow bench. Same can not be said when the head is on a running motor. :shock:
Author:  walpolla [ Thu Oct 30, 2008 3:47 pm ]
stainless valves
ex : engnbldr
regards,Rod :D
Author:  sandy in BC [ Thu Oct 30, 2008 4:37 pm ]
Unless you are pepared to spend a lot of time to do what is necessary to make bigger valves work you are wasting your time.
Optimize the 1.72s and then see where you are at.
I have 1.72 intake and 1.50 exhaust valves in my motor and it took a lot of millwork/relieving to make that half right.........
