| DC to AC inverter, safe for Valiant? https://slantsix.org/forum/viewtopic.php?t=3205 |
| Author: | Robert [ Tue Feb 05, 2002 5:26 pm ] |
| Post subject: | DC to AC inverter, safe for Valiant? |
I would like to use a cigarette lighter DC to AC inverter that uses 11-15VDC, in my 63' Valiant. Is this safe for the electrical system? Thanks, Robert. countchocula@forpresident.com |
| Author: | Dave Wordinger [ Tue Feb 05, 2002 11:19 pm ] |
| Post subject: | Re: DC to AC inverter, safe for Valiant? |
: I would like to use a cigarette lighter DC to : AC inverter that uses 11-15VDC, in my 63' : Valiant. : Is this safe for the electrical system? I've never owned a 1963, but both my 1962 and my '64 have 16 gauge wire supplying the cigar lighter. I would expect 16 gauge wire to carry 15 Amps. In 1962, the lighter circuit is fused at 14 Amps, and in 1964 they use a 20 Amp fuse for the same circuit. 20 Amp for a short period of time, say a couple minutes, is probably Ok, but if you load a 16 gauge wire with 20 Amps continuously, it will get hot and melt the insulation. If 15 Amps is safe, 15 x 12 = 180 watts. I doubt your inverter is more than 80% efficient, so 180 watts in equals 144 watts out. If you use the inverter to power anything bigger than 144 watts, you may have trouble. At best, 20 Amps into a 100% efficient inverter is 240 watts. Dave W. dwordinger@earthlink.net |
| Author: | kevin Barnwell [ Wed Feb 06, 2002 3:13 am ] |
: I've never owned a 1963, but both my 1962 and : my '64 have 16 gauge wire supplying the : cigar lighter. I would expect 16 gauge wire : to carry 15 Amps. In 1962, the lighter : circuit is fused at 14 Amps, and in 1964 : they use a 20 Amp fuse for the same circuit. : 20 Amp for a short period of time, say a : couple minutes, is probably Ok, but if you : load a 16 gauge wire with 20 Amps : continuously, it will get hot and melt the : insulation. : : If 15 Amps is safe, 15 x 12 = 180 watts. : : I doubt your inverter is more than 80% : efficient, so 180 watts in equals 144 watts : out. If you use the inverter to power : anything bigger than 144 watts, you may have : trouble. At best, 20 Amps into a 100% : efficient inverter is 240 watts. : : Dave W. Just go get an aux. lighter socket & heavy guage wire & install to battery (fused, of course) I did this to the trunk area to power various 12 volt accessories. Remember, if you are not running the car , you better have a decent battery! ktbarnwell1@juno.com |
