| No start https://slantsix.org/forum/viewtopic.php?t=32070 |
| Author: | 75plyduster [ Mon Nov 03, 2008 6:18 pm ] |
| Post subject: | No start |
I put a holley 350 cfm two barrel on my car and I disconnected all the one barrel choke but now I have no power to start my car. I was wondering if there is a ground that might was connected to the old choke that would affect this. I dont know what else it would be. |
| Author: | 75plyduster [ Sat Nov 08, 2008 8:37 am ] |
Should I ground the old connectors for the choke? |
| Author: | steponmebbbboom [ Sat Nov 08, 2008 9:30 am ] |
no. you may have bumped something, check the usual suspects like battery clamps/cables/firewall connector/fusible link. your starter may also have decided now would be the time to crap out, check the relay (follow the small starter wire back to a metal box and check connections) and in park, short the small terminal on the starter to the large one and see if it turns over. |
| Author: | 75plyduster [ Sat Nov 08, 2008 2:01 pm ] |
I just replaced the starter relay, but I still tried that an no go. |
| Author: | steponmebbbboom [ Sat Nov 08, 2008 2:27 pm ] |
what is your multimeter telling you? |
| Author: | 75plyduster [ Sat Nov 22, 2008 11:24 am ] |
Sorry for the long wait. I got it to turn over finally. I think the ingnition switch is out. |
