| Must see pics of 10 second valiant build https://slantsix.org/forum/viewtopic.php?t=32082 |
| Author: | carpdar [ Tue Nov 04, 2008 8:34 pm ] |
| Post subject: | Must see pics of 10 second valiant build |
I've stumbled across this website http://koti.mbnet.fi/trc/teknik.htm in the past but can't identify all the parts use or the language of the description. Looks like a stock forged crank, clifford rods?, and a pretty clean set of custom headers. |
| Author: | Joshie225 [ Tue Nov 04, 2008 9:34 pm ] |
We've discussed the car before. Try this link: http://koti.mbnet.fi/trc/etukeski%20eng.htm |
| Author: | carpdar [ Tue Nov 04, 2008 10:45 pm ] |
I was dreaming up a turbocharged blow-through TBI system utilizing the megasquirt v2 and a heat exchanger to help fully vaporize the fuel mixture. From what i understand a slant 6 with forged crank, arp rod bolts, stronger valve retainers, and improved camshaft lubrication should handle over 500 horsepower? |
| Author: | Matt Cramer [ Wed Nov 05, 2008 7:31 am ] |
500 hp should be safe from what I've heard if you can keep it out of detonation (and you will probably want forged pistons), but I would go multi-port instead of a TBI as you're likely to get better fuel distribution that way. |
