| Instrument panel voltage regulator https://slantsix.org/forum/viewtopic.php?t=3209 |
| Author: | Byron Spence [ Wed Feb 06, 2002 12:01 pm ] |
| Post subject: | Instrument panel voltage regulator |
I am going nuts trying to find this thing. I have a 68 dart. I cant find the regulator by reaching under the dash, so i tried to take the dash out. But, I cant get the speedo cable unscrewed from the speedo, and the gauges won't come out. Any help would be great. Byron byronpenc@hotmail.com |
| Author: | Dart270 [ Wed Feb 06, 2002 1:33 pm ] |
| Post subject: | Re: Instrument panel voltage regulator |
: I am going nuts trying to find this thing. I : have a 68 dart. I cant find the regulator by : reaching under the dash, so i tried to take : the dash out. But, I cant get the speedo : cable unscrewed from the speedo, and the : gauges won't come out. Any help would be : great. : Byron The cable doesn't unscrew, you just squeeze the cable end going into the speedo back and a little clip (looks like a fish hook) will let loose and allow you to pull the cable out. Lou |
| Author: | Dave Clement [ Thu Feb 07, 2002 5:21 am ] |
: I am going nuts trying to find this thing. I : have a 68 dart. I cant find the regulator by : reaching under the dash, so i tried to take : the dash out. But, I cant get the speedo : cable unscrewed from the speedo, and the : gauges won't come out. Any help would be : great. : Byron FYI, I have seen some Darts with the same instrument cluster as the 67-69 Barracuda's. That is, Two large round pods, one for the speedo and one for the fuel/amp/temp/oil. And, a smaller one inbetween for the tach. If you have this cluster the instrument voltage regulator is integrated into the gas gauge, that is, there is not a separate IVR on the panel. Dave Clement Hot-Rod 6 dave.clement@motorola.com |
| Author: | Byron Spence [ Thu Feb 07, 2002 9:49 am ] |
: The cable doesn't unscrew, you just squeeze the : cable end going into the speedo back and a : little clip (looks like a fish hook) will : let loose and allow you to pull the cable : out. : : Lou So, i just squeeze with pliers and pull? That sounds too easy. I will give it a shot, thanks fo the help. Byron |
| Author: | Chuck Rivers [ Thu Feb 07, 2002 3:04 pm ] |
: So, i just squeeze with pliers and pull? That : sounds too easy. I will give it a shot, : thanks fo the help. : Byron You don't need pliers, just squeeze with your fingers. Chuck webmaster@omnipages.com |
