| Gas tank for 60 Valiant https://slantsix.org/forum/viewtopic.php?t=32099 |
| Author: | HyperValiant [ Wed Nov 05, 2008 7:26 pm ] |
| Post subject: | Gas tank for 60 Valiant |
Just like the title says,I need a tank for my 60 Val and was wondering if anyone has had any luck using a different year tank as 60-61 tanks are unique and not reproduced.My current tank is not only scummy and rusty on the inside but has been dented pretty badI have even considered a fuel cell but really dont want to go that route. Is a 63 tank close enough to fit or will it not fit due to the non typical shape of the 60-61 trunk floor? Has anyone else had this problem and what was your solution? As always any help is greatly appreciated. Thanks HyperValiant |
| Author: | SlantSixDan [ Thu Nov 06, 2008 9:50 am ] |
Ooohboy. That is a toughie...I think this topic has come up before. *search search search* Yep, it's over here. It'd be nice if someone would repro the '60-'61 and/or '62 tanks. As it stands, an exotic replacement such as a custom fuel cell might be about the only way to have a new one... |
| Author: | Reed [ Thu Nov 06, 2008 10:53 am ] |
Awww, what's wrong with air shocks, leaf spring extension shackles, and a 55 gallon drum? |
| Author: | VDART [ Fri Nov 07, 2008 4:55 am ] |
| Post subject: | 60 fuel tank |
if you decide to go later style route I have a nice used 66 dart tank/sender you could have for shipping, Lawrence |
| Author: | HyperValiant [ Fri Nov 07, 2008 7:23 pm ] |
Thanks for the replys ,I may try to straighten the dent and line the tank. I would really hate to modify the trunk floor but I may have to and run a 63 tank.Once again ,thanks for the replys. HyperValiant |
